Brake goes to floor when truck is started on a 1998 Jimmy with ABS
Old 09-21-11, 04:27 PM
T
Hi all.
Hopefully someone can help me. When I press the brake pedal, it works good when truck is off. When I start the truck, it almost goes to the floor. Maybe I need to spend more time bleeding the brakes. But I'm sure I did it right.
Here is what I've tried so far:
1. Replaced bad rotor, caliper, and pads.
2. Replaced master cylinder.
3. Bled the brakes <with truck running and a helper>.
This is a 1998 GMC Jimmy 4WD with ABS. 4.3 ltr V6 Engine SLT model.
Thnx in advance
Tim
Old 09-21-11, 04:51 PM
ukrbyk's Avatar
Received 43 Votes on 35 Posts
you didn't bleed the master, did you?
Old 09-21-11, 04:54 PM
ukrbyk's Avatar
Old 09-21-11, 04:55 PM
T
Sorry for my ignorance..what do you mean by the master? The master cylinder??
No..just the four wheels. Don't see a spot to do it on the master cylinder.
Old 09-21-11, 04:57 PM
ukrbyk's Avatar
yes, of course. I should have been more explicit, my bad.
Old 09-21-11, 07:21 PM
T
Thats' ok. Thanx for the quick responses. Maybe I'll just try bleeding them longer and see what happens. Don't see any leaks anywhere at all, although the lines are pretty rusty looking.
Old 09-22-11, 04:34 AM
the_tow_guy's Avatar
Received 145 Votes on 113 Posts
Bleeding the master (bench bleeding):
Master Cylinder Bleeding - How To Bench Bleed Your Master Cylinder - Remove Air Bubbles
A lot of masters will come with the little plastic fittings and hoses included to to this.
Old 09-22-11, 12:07 PM
ukrbyk's Avatar
you can bleed master on car using same kit. thereafter, you have to bleed brakes again.
Old 09-22-11, 03:52 PM
T
Thanx again guys. Will try this and see what happens. Also, someone mentioned to me it could be the power assist hose or something.Check to make sure there is a vacuum in it when you apply the brakes or the hose/valve could be no good. Hope you know what I"m talking about here
Old 10-08-11, 09:03 PM
T
Well, still trying to get these brakes fixed. Bleeded the brakes about 10 times now and still nothing. The brake peddle is a little bit harder to push now when the truck is running, but not much better. I checked and there is a vacuum on the hose that leads to the master cylinder housing. Any more thoughts before I have to give up on this project
Old 10-30-11, 10:07 PM
T
you may have to use a scanner to bleed the ABS hydraulic control unit
