1994 buick park ave.rear suspension
Old 09-24-11, 01:12 AM
i need instructions to remove the rear air assist struts on my 1994 park ave.
Old 10-04-11, 05:02 PM
I guess it's better late than never. If you still need them, here they are...
1.Raise and safely support the vehicle.
2.Remove the trunk side cover. Remove the tire and wheel assemblies.
3.Support the control arm with a suitable jack.
4.Disconnect the Electronic Level Control (ELC) air tube and separate from the strut air tube, if equipped. If equipped with Computer Command Ride (CCR), disconnect the strut electrical connector from the harness.
5.Disconnect the strut tower mounting nuts. The nuts are located inside the trunk.
6.Remove the strut anchor bolts, washers and nuts from the steering knuckle and bracket.
7.Remove the strut assembly from the vehicle.
To install:
8.Install the strut assembly and connect the upper strut mounting nuts.
9.Replace the strut anchor bolts, washer, knuckle bracket and nuts.
10.Connect the ELC tube or CCR connector if equipped.
11.Tighten the upper mount nuts to 35 ft. lbs. (47 Nm) and the strut-to-knuckle nuts to 140 ft. lbs. (190 Nm).
12.Replace the tire and wheel assemblies. Remove the jack from under the vehicle.
13.Replace the trunk side cover and lower the vehicle.
