Cruise Control
Old 09-28-11, 05:03 PM
Cruise Control
I have a 2000 Olds Alero, and the cruise will not come on, when press the on switch it will light up but will not hold, light goes back
Old 09-28-11, 09:09 PM
It sounds like it could be a problem with your cruise control brake switch located at your brake pedal arm beside the stop light switch. If the contacts inside this switch are not working correctly it can cause this problem by incorrectly telling the system that you are depressing your brake pedal.
Old 09-29-11, 08:09 PM
I have took a coin and used it to hold the cruise on but after a few miles the cruise started to surge up and down approx. 2 to 5 miles a hour, enough to make u car sick
