96 Dodge Grand Caravan NO SPARK
Old 10-05-11, 06:45 PM
So i own a 96 dodge grand caravan with a 3.8L that quit while driving down the road. Motor cranks but does not start. I have replaced ignition coil, cam position sensor and crank position sensor. still no spark. Also i have checked main fuses and auto shut down relay. No trouble codes.
Old 10-05-11, 09:19 PM
You sound very sure it is spark problem and not a fuel supply issue? How did you confirm this?
Old 10-06-11, 01:16 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
Old 10-12-11, 08:12 PM
i have fuel at the injectors, tested the pressure and all is good. I have a spark tester that i hooked to the coil and it gives me no spark.
