2000 Honda CR-V woes
Old 10-23-11, 10:34 AM
daswede's Avatar
My daughters CR-V 'check engine light' is on. When i went to change the spark plugs for her,i found all the spark plug wells filled with oil.
Is this a expensive fix, and worth any further repairs? Car has 140k on odo.
Thanks
Old 10-23-11, 11:06 AM
ukrbyk's Avatar
Received 43 Votes on 35 Posts
easy peasy but needs know-how. you need to replace vlave cover and rocker arms towers seals.
here's our g'ol buddy Eric the car guy with step by step:
Spark Plug Well Oil Leak Fix, Honda Accord - YouTube
PS to make it clear - yours is identical or very similar. BTW, with valve cover off, when done, adjust rockers. She's long due on this. Careful with adjustment bolts!! They can crack if over-torqued!!
Old 10-23-11, 11:59 AM
daswede's Avatar
ukrbyk,
Many thanks for your reply. The video you showed was just what i wanted to see.
Many thanks
Old 10-24-11, 08:02 PM
ukrbyk's Avatar
he-he. he finished the job, yakking a lot, in 22 minutes. will you be the guy to beat it in 20?
