2002 pontiac bonneville check engine code
Old 10-24-11, 07:53 AM
check engine light came on and got the code scanned and the code was P1441 anyone knows what that code means?
Thanks
Old 10-24-11, 08:07 AM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
Gas cap?....................
Reinstall it or get a new one. Make sure it clicks when you tighten.
Code will clear after a couple hours of driving if its the issue.
Most likely it is. let us know.
Mike NJ
Old 10-24-11, 09:57 AM
Question
this is what i googled and found
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
whatever that means???
Old 10-24-11, 04:56 PM
the_tow_guy's Avatar
Received 146 Votes on 114 Posts
Somewhat self-explanatory. There is flow being sensed through the purge line when the purge valve should be closed. In the evap system, fuel vapors are captured from the tank and stored in the charcoal cannister. At a pre-determined time, like right after startup (someone help me out here if I don't have it exactly right), the purge valve opens for a short time and the collected vapors are sucked into the intake system to be burned with normal combustion; then the valve closes until next time. I don't know if that particular code would indicate a leaking purge valve, but that would be a possibility.
Here's some more info:
EVAP Evaporative Emission Control System
