92 Honda Accord Idler Control Valve
Old 10-31-11, 09:48 AM
F
Gas mileage horrible, idles high, dealer says idler control valve and entire throttle body needs to be replaced. $500 price tag.
I understand if a car hasn't been in a salvage yard too long, a salvage one should be ok.
I am also told that a shop that does some work for me can fix the one I have. How? Is it a DIY thing?
We used some seafoam earlier this year, stuff like that.
Suggestions? Advice?
Old 10-31-11, 11:09 AM
Received 18 Votes on 13 Posts
The dealer is probably the LAST place to take your car... the repairs will certainly exceed the car's value !!
Try the shop that you know.
Old 10-31-11, 06:15 PM
ukrbyk's Avatar
Received 43 Votes on 35 Posts
just take idler valve out and clean it. it is coolant warmed, or whatever, and builds up sedoment inside, like an old kettle. it's quite a job, as it has tiny coolant lines connected to it and they are pita to disconnect. then simply take cover off, clean it all inside, and blow some brake cleaner through every hole.
I bet you can also do same to throttle body. simply take it off and give it good bath.
sounds DIY well enough to me.
