windshield washer
windshield washer
I have a 2004 ford expedition the front washer stopped working i checked fuse,checked for power at pump.Had power changed pump,still have pwer at pump hooked pump up directly to battery spray's fine just won't work when i push switch on colum
Check for power on one leg of the switch with the car running but switch off. No power - trace back to fuse block. If you have power, push and hold the spray button and check the other leg of the switch for power. If no power, replace the switch. If there is power trace the wire to the washer pump and check there.
washer
thank's for the quick response i'm going to try to check it more today after working on it yesterday took it out last night and now brake light's don't work either hope it's a fuse
