1994 Mercury Topaz 4 cyl - starting problem
Old 02-26-12, 06:45 AM
1994 Mercury Topaz starting problem. Car was starting fine - not being driven for about 4 months but being started and let run for about 1 hour every couple of weeks with no problems. Let it go for about 3 weeks without starting it and then it wouldn't start. No click when turning key. Replaced starter solenoid and still nothing. The battery is fully charged.
I tried a test I saw online, turned on the wipers before trying to start the engine, when I turned the key the wipers stopped.
Any ideas on what the issue might be and what else I can try - thanks.
Old 02-26-12, 08:23 AM
Does you vehicle have any kind of anti-theft protection (security)?
Did you try to start the vehicle in neutral if it is an automatic and or moving it between park and neutral a few times? (safety interlock switch) could be failing. Assuming there is no security system and the vehicle is an automatic, the neutral switch would be my first guess.
Old 02-26-12, 08:46 AM
Gunguy45's Avatar
Super Moderator
Don't assume the battery is fully charged just by a voltage check...it needs to be load tested as well.
Old 02-26-12, 09:15 AM
The vehicle doesn't have a security system. I bought the battery new 3 months ago and I had it rechecked and it's fine. I tried starting the vehicle in neutral, it still didn't do anything.
Old 02-26-12, 10:24 AM
the_tow_guy's Avatar
Battery cables/connections or fuse/relay in the starter circuit; maybe even just the ignition switch.
Old 02-26-12, 10:35 AM
What fuse/relay could cause this issue and where is it located? Thanks.
Old 02-26-12, 05:40 PM
Lets just cut to the chase. Take a test lamp ground the clamp. touch the lead that gets power when you crank. I have seen the inside of battery cables get very corroded. Also jump out the two heavy bolts on the solenoid. If it still won't crank bad ground/stater.
Rob
Old 03-03-12, 06:15 AM
OK, I've checked everything and the problem seems to be pointing towards the ignition switch. I've got the switch and am getting ready to replace it. Does anyone know what size/type torque bit is required for this model? Thanks.
Old 03-03-12, 07:52 AM
I don't know that anyone will know that off of the top of the head; might want to just buy a set of Torx drivers.
Old 03-03-12, 01:50 PM
I have torque bits, but connector on the ignition switch looks like a torgue bit but has a pin in the middle that doesn't let the torque bit set. That's why I asked what type of bit, never seen one like that. Thanks.
Old 03-03-12, 02:06 PM
Ugh, that's one of those tamper-resistant Torx; I don't know what to tell you about those. Maybe someone can jump in here with thoughts.
Old 03-03-12, 02:16 PM
Gunguy45's Avatar
Super Moderator
You can buy a tamper proof set almost anywhere that sells hand tools. Pretty sure both HD and Sears have them...
I think I got mine at a discount bin at Pep Boys or Autozone...
Yep...HD has 'em...mine were cheaper though....
11 -Pieces Torx Tamper Insert Bit Socket Set-80724 at The Home Depot
Old 03-03-12, 02:22 PM
Didn't know they had them, guess I'll pick up a set so I don't have to mooch when I need one.
Old 03-03-12, 02:34 PM
Gunguy45's Avatar
Super Moderator
Actually...they don't show those in stock at my store I realized...but thats probably an anti-crime thing out here.
I know many places carry them...Autozone shows almost identical to what I have for $10
Old 03-12-12, 05:30 AM
I picked up a set of the bits at O'reillys, replaced the ignition switch and everything is working fine now. Thanks for the advise on this issue from everyone, it'g greatly appreciated.
