98 Toyota Land Cruiser - Brakes Grinding & Locking Up
Old 02-27-12, 04:30 PM
Hello -
A week ago, I replaced the brake pads on the 2 front wheels on my Land Cruiser. Today, I was driving and taking an interstate exit when I started applying the brakes. When I did, there was heavy grinding as well as the wheel seemingly locking up.
This happened at all speeds, but seemingly not in reverse. Without taking it apart, I didn't see anything wrong. I had to use my emergency brake only to get where I was going.
Any suggestions on what it may be? Someone suggested a sensor may be messed up due to not bleeding the brakes last week and may be off balanced, but doesn't sound right to me
Thanks!
Old 02-27-12, 05:31 PM
the_tow_guy's Avatar
Received 38 Votes on 30 Posts
No reason to bleed the brakes if all you did was pads. Is there any damage to the rotors? Sounds like maybe a locked up caliper.
Old 02-27-12, 06:12 PM
Well, I had planned to change a rotor too, but didn't have the proper tools. Didn't find that out until after I had the caliper completely off, though.
Lost some fluid, but had the line clamped. Filled the fluid back up, but sure there's air in it. Worked fine for a week though. Weird how it seems the brake on that wheel seems either on or off - not gradual. It has banging noises, too.
Old 02-28-12, 09:16 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
hmmm.... pads sitting crooked on guides? at least, one? did you lubricate pads seats and caliper pins? was caliper sliding back and forth from hand easily?
Old 02-29-12, 05:19 AM
Maybe I'm a little thick this morning, but two questions leaped to mind: Why would you lose any fluid during a pad change and why would you need to clamp off the hose? it's a closed system unless you have a leak or loosen fittings.
Old 02-29-12, 09:20 AM
I think he removed brake hose from caliper when changing the pads.
Old 03-05-12, 09:23 AM
Had one act like this one time and a rock had gotten lodged by the pads.
