1990 Toyota Corolla won't start
Old 03-10-12, 01:53 PM
This vehicle had been setting for about 18 months.
Vehicle turns over strong
Sequence of events.
Replaced Plugs
Replaced Plug Wires
Replaced Distributor Cap
Replaced Rotor
Replaced Ignition Coil
Still would not start. I noted that the Check Engine light was not coming on.
Replaced EFI Fuse(blown)
Starts to run, with Starter Fluid, and then shuts off(Blows Fuse)
Check Engine light come on while starting
Replaced Fuel Pump
No more blown fuses
With stater fluid, ran for about 2 mins, shut off.
Unable to restart
Check Engine light not coming on at all.
Pumped out as much old gas as I could and put in fresh gas.
Will not restart and Check Engine light not coming on.
Any thought, hopes or prayers for this?
Thank you very much,
Roger
Old 03-10-12, 01:59 PM
Welcome to the forums Roger!
My son has 2 cars like yours - kind of sporty
Have you checked the fuel pressure? replaced fuel filter?
Old 03-10-12, 02:06 PM
Fuel Filter NO
Fuel Pressure at the rail, got pressure. I do not have a way of telling how much, but I do have pressure.
Old 03-10-12, 04:00 PM
UPDATE
EFI Relay. I have power to the control side of the relay but no power to the contact side of the relay.
