Rear window washer
Old 03-15-12, 12:32 PM
Rear window washer
I have a 2002 blazer, and the rear window washer doesn't work. I looked in the manual, and that wasn't very much help. About all it said, is there is just the one tank in the front under the hood, and it had to be at least half full for the rear to work. I have it full, you can hear the motor run, but nothing sprays in the back, and I don't see any leaks, or anything dripping on the ground.
Old 03-15-12, 12:35 PM
Gunguy45's Avatar
Super Moderator
Likely the sprayer is clogged. Is it the type on the wiper or the fixed nozzle that sprays on the glass?
A needle can be used to open the orifice.
Only way to know for sure is to disconnect the hose that feeds it and activate the pump.
Old 03-15-12, 03:45 PM
I most be having a bad day, I can't believe I didn't think about the nozzle being plugged. Thanks for the help, I will need to check it tomorrow if it ever stops raining.
