Where EXACTLY are the crank sensors on my 1994 Chevy Beretta Z26 V6 3.1?
Old 05-05-12, 10:54 AM
We are catching the devil trying to locate the two crank sensors and cam sensor on my 1994 Chevrolet Beretta 3.1 Cylinder. Does anybody know exactly where to find them? And does anyone have a diagram of where they are located on the engine?
Old 05-05-12, 11:53 AM
lawrosa's Avatar
Super Moderator
Received 37 Votes on 32 Posts
Crank sensors are usually near and around the water pump. You may need to remove stuff to get at it.
The motor is inline correct? Probably best to remove the wheel and wheel well shroud to access it.
The cam sensor I am looking for info.
The Haynes manual don't tell you?
Mike NJ
Old 05-05-12, 12:10 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
The GM 3.1 crankshaft position sensor is a cylindrical-shaped sensor located behind the crankshaft pulley. The sensor has three wires on its connector.
Old 05-08-12, 02:21 PM
Thank you very much for the info. So, the 1994 Beretta only has one crank sensor?
