hard crud in disc rotor
Old 07-08-12, 10:11 AM
sgull's Avatar
I noticed within one of the air space sections around the outside of the disc brake rotor I had this hard crusty stuff embedded into it somehow: http://i207.photobucket.com/albums/b...1/IMG_1825.jpg
It's kind of like a hard white crusty corrosion and almost concrete-like in hardness but maybe not that hard. I tried to maybe chip it out a little with a hammer and old screwdriver but it didn't really start to chip out very easily. What is this, how do I get it out? thanks
Old 07-09-12, 08:27 PM
ukrbyk's Avatar
Caked clay from high temperatures? Soak it in kerosine see what happens.
Old 07-10-12, 02:21 AM
if it does not work, u could drive it till u need a new rotor, then it would solve that problem
Old 07-12-12, 04:38 PM
It could very well be concrete that wedged into the gap.
Old 07-12-12, 05:22 PM
sgull's Avatar
I was thinking of trying to drill out with a masonry bit.
Old 07-12-12, 07:06 PM
ukrbyk's Avatar
why you so concerned with it?
Have Dremel?
Old 07-12-12, 09:09 PM
sgull's Avatar
I guess having that one vent clogged could contribute to excess heat buildup on the disc. Not really sure if it would be much of a concern. Yeah I have a Dremel. Maybe Dremel it out if I had the right type of bit I suppose.
Either that or just leave it alone and stop worrying about it.
Old 07-13-12, 04:51 AM
the_tow_guy's Avatar
I would try easier approach first; punch and a hammer.
Old 07-13-12, 06:43 AM
Not just heat, it's also a balance issue.
Old 07-13-12, 08:20 PM
ukrbyk's Avatar
Read more: http://www.doityourself.com/forum/pa...#ixzz20YzLxdeu
