fuse relay box underhood question???
Old 07-17-12, 07:39 AM
N
how does one get to the under side of the relays in the underhood fuse box or inside of it. I need to check one of the sockets to see what the problem is . The relay is way to loose in the socket causing problems. I can wiggle it a little and it works ok but i need to see what's going on with it . its a delphi box on a 03 chevy malibu. thanks
Old 07-17-12, 02:00 PM
chandler's Avatar
Received 5 Votes on 5 Posts
There's nothing under the relay but receivers for the pins on the relay. You can pull the relay out and look at the connectors, but if it ain't broke...............
Old 07-17-12, 04:27 PM
N
I'm just saying the relay is just sitting in the socket, if you pull it out there is no resistance at all. It would probably bounce out if you hit a bump if it were not for the cover over it. I thought if i could get to the bottom i could maybe fix it. But i can't figure out how to separate the top from the bottom, i don't see any clips around the edge.
