94 ALTIMA ignition
94 ALTIMA ignition
now it just refuses to start, here is what i have tried so far.
testd battery-ok
testd starter-ok
chked fuses and ignition relays-ok
changed ignition lock cylinder and switch
conditions
when the key is turned to start the clock display goes off (not dim)
warning chime-ok
instrument lights-ok
headlites, brake light, interior lights, etc good. do not dim when key turned to start position.
wipers work but when key turned to start position they stop dead.
the car has a security key (kill switch key) that is always in place, never removed for so long cant even remember last time it was used.
someone please help.
any clues will be greatly appreciated. thanks.
more info
thanks for the responses,
yes it is an aftermarket system by ATS, Advanced Technology Systems. it is a 8 pin "key" that disables the car from starting. it is so cheap looking that i never used it. left it plugged in all the time.
the new key i installed is an ignition key ( no chip ) and it checks out fine. seen last post i have also checked;
inhibitor switch ( prnd switch ) - ok
power transistor - ok
ignition coil - ok
solenoid - ok
i want to remove this anti-theft system. any ideas?
thanks, lokahi
ignition coil - ok
solenoid - ok
thanks, lokahi
I know this is diy.com, but sometimes you have to surrender and take it to a garage; in your case one that's good at electrical troubleshooting. Your kind of issue doesn't really lend itself to diagnosing on a forum.
