1991 Toyota w/ a wet rear floorboard
Old 07-18-12, 12:57 PM
Plz help shed some light on this situation 4 me. When I run my a.c. My passenger side rear floor gets very wet. I'm guessing there is a drain-line or a hose that's clogged, but have no idea where it is or how to go about fixing the issue. Any help would be great, thanks
Old 07-18-12, 01:45 PM
Welcome to the forums
What kind of Toyota?
Old 07-18-12, 02:32 PM
the_tow_guy's Avatar
Model would definitely help.
Usually only get that kind of problem in the front pax side from clogged condensate drain. It would take quite a quantity to wick its way to the back.
Old 07-18-12, 05:05 PM
Under the pass seat there is a a.c. Vent for the floor... Guessing for the rear? Only comes on the loaded edition I think.
Old 07-18-12, 05:09 PM
My car is a Camry V6 LE. It has all options except leather & sunroof
Old 07-19-12, 04:59 AM
Built-in seat cooling perhaps? Don't know if that's a Camry option or not. At any rate if you're getting water on the floor with the ac running it's going to be a clogged drain of some kind.
Old 07-19-12, 03:25 PM
I agree with The Tow Guy. Did you check inside the plastic HVAC vent under the front seat to check for obvious moisture/water when the AC is running and set on lower vent position?
Old 07-20-12, 12:46 PM
Thanks
I will check things out.... Was hoping it was something under the car that I could unclog with a pipe cleaner or something... Guess the carpet needs to be pulled back and I should investigate under it.
Old 07-20-12, 09:29 PM
If you find a drain tube and it's clogged, best to clear it by sucking with a shop vac.
