2 button 2 wire electric door lock switch
I'm trying to be able to unlock the card using RFID. The problem is I don't understant how the current unlock all doors work. There's the lock and the unlock button on the same switch, but only 2 wire. I just can't understand how it could work.
For all it maters, it's an 2006 saturn ion
Could you make a drawing of it? I still don't understand.
My thinking: to work, the solenoid must have a ground and a positive side. I guess the ground is on taken from the door yea, but what about the positive side? It can come from either lock or unlock wire. But what about those two, where do they take it?
ground-------solenoid------lock
|...................unlock------switch
(-)Battery(+)-----?
(-)Battery(+)-----?
like I said - I am dumm electrically. I just sorta thought - if you have constant ground from door metal, then the 2 wires in question are always (+) and switches are simple breaker type. You close one switch - trips solenoid into lock, close the other one - trips solenoid into unlock.
Solenoid prolly has some sort of a disconnect configuration, so that when it tripped into Lock, there is no more power supplied to it, or it will not unlock. Like, say, having 2 independent coils in it, one to lock and one to unlock.
JUst guessing. Surprised no one else, more learned on electricity, didn't pitch in.
The switch isn't wired to the door, it's exactly like the picture I posted. I got confirmation from another website. But it's a 1.5k ohm resistance that must be used instead of the one on the picture.
I'll come back to confirm once I try, it's a holyday now and election tommorow so maybe in 2 days
Oh, I never said switch to be wired to the door. I said - lock actuator(solenoid) is grounded to the door metal. So you have negative from there and positive from wires. Wild guess though. Plenty of that type connections all over any vehicle.
