2003 Mazda 6i - engine cuts out
Old 09-29-12, 06:36 PM
My 2003 Mazda 6 that has a 2.7 liter 4 cylinder engine has a problem. It will be idling at 750 rpm very smoothly and will suddenly nearly die. It rarely dies all the way but the tach drops to near zero and then it will bounce back to a normal idle rpm. The only trouble code that has been trapped is a P0456, which is a very small leak in the EVAP system, but that has been around for quite some time.
I'm guessing that the problem might be a crankshaft sensor. Would appreciate hearing about other likely alternatives.
Thanks in advance for your help!
Mike
Old 09-29-12, 10:14 PM
iceman681's Avatar
is it only at idle? if so id look for vacuum leaks, or bad idle air control valve. if not could be crank sensor, ignition system, or mass air flow.
Old 09-30-12, 09:26 AM
ukrbyk's Avatar
toss in fuel pump, fuel regulator, and ECU.
Old 09-30-12, 12:24 PM
only happens at idle. there is no rough idle preceeding the sudden rpm decline. just falls off a cliff and just as quickly returns to a normal idle of 750 rpm.
Old 09-30-12, 01:34 PM
ukrbyk's Avatar
that's why I am leaning towards fuel pump of fuel regulator. locate your fuel pump, should be underneath the rear seat, and clean all connections. ALL. same goes for fuel regulator.
also, run a can of decent cleaner through several tankfuls.
