Rounded Out Locking Lug Nut Stuck
Old 10-12-12, 12:48 PM
F
Removed one locking lug with a torch
Removed one locking lug by pounding on a 13/16
This one though is not going anywhere.
Tried pounding a 13/16, tried JB weld, now the locking lug is rounded. Any suggestions?
Old 10-12-12, 01:25 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Maybe trying the key that came with the wheels??? You can buy nut ez outs, too. I have a set and they are great for rounded bolt heads. They really grab firmly and the more you torque them the more the dig in. What did you do with the JB Weld, just curious.
Old 10-12-12, 02:23 PM
the_tow_guy's Avatar
Received 144 Votes on 112 Posts
Only problem is they come in a set @ about $70 or so.
Old 10-12-12, 03:24 PM
F
Funny Guy,
What did I do with the JB weld? I put it in my toolbox, ,. The JB weld was applied sparingly inside a deep socket. Maybe a short 13/16 and lots of JB weld should be tried.
Out of Generosity,
Flatbread
P.S. The EZ Outs remind me of last yr when I learned about left handed threads. @ 70 set ,whew, maybe that is why do not have any
P.S.S. Obviously did not learn much, Is an Ez Out=screw extractor=left hand threads?
Old 10-12-12, 03:44 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
I saw a Craftsman set of 5 (no clue as to sizes) that was only $20. I doubt they go above 5/8 or so though.
Irwin sells something similar at HD.
The_tow_guy said this 5 yrs ago....
"Nap has the right idea; any decent tire shop should have a female easy-out impact socket for removing rounded off nuts."
Read more: http://www.doityourself.com/forum/pa...#ixzz297xysMRe
Old 10-13-12, 11:38 PM
F
craftsman set of 5 biggest one was 3/4
was able to get the lug off with a diff. 13/16 , pounded it till it nearly hit the wheel,
could not even use a 4 way on the other 4 "regular" lugs
Old 10-14-12, 06:24 AM
Were you able to get the nut back out of the socket or did you have to sacrifice it?
Old 10-24-12, 06:47 PM
F
Yes, I was able to get the nut back out of the socket.
Old 10-25-12, 07:49 AM
T
I've heard that one can pound a sacrificial short piece of pipe on to a locking lug and then use channel locks to break that loose. Never tried it myself though.
Old 10-25-12, 08:30 PM
C
Lock nut problem
You could of also used a pipe wrench with an extension bar. This works really good...and a lot cheaper too.
Old 10-26-12, 04:21 AM
Depends on the design of the wheel. On some you wouldn't be able to get an angle to get the wrench on the nut. Would work with the proper clearance.
