2005 sebring acting up after 3k rpm
Old 10-19-12, 11:21 AM
2005, sebring 6 cylinder, 120k miles, engine jerks when you hit 3k rpm and have to back off to get it to stop jerking.
No fuel filter to change, changed cam shaft position sensor, didn't help.
Any help????
Thanx
Old 10-19-12, 11:24 AM
Have you checked to see if there are any codes in the computer?
Old 10-19-12, 12:31 PM
Check your plugs and coil packs. My father inlaw had the very same issues with his sebring. We changed the plugs and noticed a damaged coil pack.
Just a note, plugs are brutal on those cars to get in and out.
I had to use a 3" extension and a universal to get the back ones out. The coil packs (one per sparkplug) are also a pain. Believe they where a T8 bit or 10mm nut (can't remember which was his and which was my car).
Oh, and wear gloves. The fiberglass insulation on the firewall while irritate your knuckles for days afterwards.
Old 10-19-12, 06:27 PM
the_tow_guy's Avatar
Second Mike's suggestions; high rpm missing/cutting out is a classic symptom of plugs/plug wires/ignition problems.
Trackbacks are On
Pingbacks are On
Refbacks are On
