Rounded Out Locking Lug Nut Stuck
Removed one locking lug with a torch
Removed one locking lug by pounding on a 13/16
This one though is not going anywhere.
Tried pounding a 13/16, tried JB weld, now the locking lug is rounded. Any suggestions?
Maybe trying the key that came with the wheels??? You can buy nut ez outs, too. I have a set and they are great for rounded bolt heads. They really grab firmly and the more you torque them the more the dig in. What did you do with the JB Weld, just curious.
Funny Guy,
What did I do with the JB weld? I put it in my toolbox, ,. The JB weld was applied sparingly inside a deep socket. Maybe a short 13/16 and lots of JB weld should be tried.
P.S.S. Obviously did not learn much, Is an Ez Out=screw extractor=left hand threads?
Out of Generosity,
Flatbread
P.S. The EZ Outs remind me of last yr when I learned about left handed threads. @ 70 set ,whew, maybe that is why do not have anyFlatbread
I saw a Craftsman set of 5 (no clue as to sizes) that was only $20. I doubt they go above 5/8 or so though.
Irwin sells something similar at HD.
The_tow_guy said this 5 yrs ago....
"Nap has the right idea; any decent tire shop should have a female easy-out impact socket for removing rounded off nuts."
Read more: http://www.doityourself.com/forum/pa...#ixzz297xysMRe
craftsman set of 5 biggest one was 3/4
was able to get the lug off with a diff. 13/16 , pounded it till it nearly hit the wheel,
could not even use a 4 way on the other 4 "regular" lugs
