brakes stuck in up position 2001 PT Cruis
Old 11-06-12, 04:36 PM
When to start the car and the brakes were stouck in the up position, attempted to press down, nothing happened. Then started the car again and all was fine. I then decided to press down several times and then again brake stuck in up position, any thoughts please, thanks
Old 11-06-12, 06:18 PM
ukrbyk's Avatar
Brake pedal does not move down?
First thing first - get down there and look for any obstacles, like carpet, floor mat, something wrapped around the pedal.
Old 11-07-12, 08:18 AM
How many miles?
Sometimes the hydraulic hoses that attach the hard brake lines to the calipers or wheel cylinders can fail internally where they don't let pressure through one way or another. Generally this failure is a result of temperature or a lot of usage, or of improper support for the caliper while it's off of the caliper mount.
Old 11-07-12, 03:27 PM
iceman681's Avatar
my guess is a vacuum leak to the booster, but this is a tuff one. but id start with ukrbyk's idea.
Old 11-07-12, 04:37 PM
ukrbyk's Avatar
well, we still do not know what exactly he meant...
I am yet to see - and feel - a brake pedal that does not go down at all. even with engine not running - it still has some give.
