92 Mercury Topaz shift issues
92 Merc Topaz automatic. When you take off, the tranny shifts from 1st to 2nd fine and right away shifts half-way into drive. If you manually shift back into 2nd and then accelerate some and shift back into drive, it shifts all the way in and drives fine. Also, when you accelerate hard to pass or go up a hill say, it will not down shift to second automatically. Is this a modulator or sensor problem or is the tranny screwed ?
Thought so myself. But, what I think he's saying is that trannie simply got mind of its own and slips out of gears.
But that's my guess. We need his confirmation and clarification. EG, I have no idea what this means:
How can a gear engage half-way?
no mind of its own. under normal acceleration, it shifts into 2nd and then into drive about 1 second later. When it goes into drive it is like it' s not all there. Lack of power, slipping. If you shift into 2nd manually and accelerate for say 4-5 seconds, it goes into drive and seems normal. Also, if you accelerate hard it will not kick down into 2nd at all.
yeah, so my guess is actually correct, go figure. your trannie silps and such, not gear shifter not doing its job.
your clutches are slipping and your valves are sticky. next thing to happen will be - you put her into gear, and nothing happens. as in - it's in D, but no movement. I know, I had 2 Ford trannies fail on me in matter of 2 weeks, on Sable and Taurus. One on Sable first warning sign was - will slip[ out of overdrive by itself, don't even remeber what I had to do to make it go back into overdrive. Same gear shifter manipulations. Then, it simply stopped moving vehicle. Was 91 Sable, I believe.
