1997 Audi Quattro fuses
Old 11-25-12, 02:24 PM
N
Hi. You guys have always been insanely informative in the past so here goes. My daughter just got a 97 Audi Quattro. Runs and looks beautiful. Only problem is the radio and blinkers do not work. We thought it could be a fuse problem. But there is no manual and the fuse box does not tell you what fuse controls what. Any help would be greatly appreciated. Thanks
Old 11-25-12, 03:39 PM
ukrbyk's Avatar
Received 43 Votes on 35 Posts
Aahhh... Library? Any parts store and repair manual? For the year, you'll need one anyway.
You sure bulbs in "blinkers" are not bad, or, simply, loose, or corroded?
Old 11-25-12, 03:40 PM
ukrbyk's Avatar
Oh, and if someone replaced battery just before sale, to make sure that it sells, headunit will not work. Will require security code. But it sounds like yours has more issue than that.
Old 11-25-12, 04:01 PM
Received 2,961 Votes on 2,672 Posts
A 12 volt test light is a great inexpensive testing device to have in your toolbox.
Makes fuse testing a snap, even when you don't know what fuse you are looking for.
