2000 Camry..leaks like Niagra Falls
Old 11-28-12, 05:25 PM
F
Is it the Sunroof? The water literally pours out from under the steering wheel area under the dash. Do I take a pressure tank to the "pee-holes" and blow out pine needles or whatever? I don't know where the holes are located though. I hear that the local Tyota dealer will do a "soak test" for over $150 and that is before the repair charge...any other Camry owners or smart mechanics have a solution? I'm at the point where I want to soak test it myself...with Drain-O.
Thanks for your help...if you can. Tom
Old 11-28-12, 07:55 PM
the_tow_guy's Avatar
Received 153 Votes on 118 Posts
Under the steering wheel would tend to point to the windshield vice the sunroof. AFAIK most sunroofs drain through the "B" pillar. For $150 I would definitely be doing my own test with a garden house and a flashlight.
Old 11-28-12, 07:59 PM
XSleeper's Avatar
Received 1,534 Votes on 1,378 Posts
I would agree... the seal around the windshield is probably leaking. Turn the hose on it and see.
Drain-o? You can't be serious.
