1987 honda accord lx coolant in oil
Old 12-11-12, 10:58 AM
Sorry new to the site and not sure how to start a new (?) thread... I have an 87 honda accord with coolant in my oil ? Had the head gasket replaced and the head milled, I was hoping there was not a crack in the block. Is there anyplace else coolant could be leaking into my oil from ???
Old 01-09-13, 05:45 PM
Some vehicles like my 96 blazer have been known to leak coolant from the intake manifold. It can either leak internal or external, external in my case. If your car has coolant passages running up at the intake manifold chances are the intake manifold gasket has an internal leak. Other than that I would have to do more research for your particular issue.
Old 01-09-13, 07:41 PM
iceman681's Avatar
nope there is no other way other than adding it yourself. unless its pink then its trans fluid and a radiator could do that. also i would say if the head warped, so did the block.
