reprogramming car remote
Old 01-01-13, 07:56 PM
Roeboat109's Avatar
I have a 2008 chrysler t&c that has 7 buttons on it for side doors ,rear hatch,engine starter.I installed a new battery in it so i guess i need to reprogram it.Any one know how to do this on a 2008 chrysler t&c? Thanks for any help.
Old 01-01-13, 08:02 PM
If it was already programmed to that vehicle.....it should still be.
A dead battery will not cause it to be unprogrammed from the vehicle.
If it doesn't work after replacing the battery.......
make sure the battery is good and make sure it's in the correct way.
If it turns out that it must be reprogrammed into vehicle......in order to do it yourself......you would need another working remote. Otherwise only the dealer can reprogram it for you.
Old 01-01-13, 08:04 PM
iceman681's Avatar
should not need to be reprogrammed. i would make sure you installed the battery correctly. the body control module is programed with a id number of the remote and changing the battery will not affect that. if you are having issues and the battery is installed right then there is a bigger issue.
ur quick pjmax
Old 01-02-13, 06:01 PM
Roeboat109's Avatar
van remote not working
I took it out to the dealership and they fixed it.It just wasn't making good contact.Thanks for your help.
