'05 Chrysler Town & Country Van No Heat
Old 01-22-13, 09:49 AM
I have an '05 Chrysler T&C van and in the past couple days there has been no heat even after it has been running a while. I have checked the fluids and everything is filled however I believe there is a small leak in the radiator and I put some Prestone radiator stop leak in it however it doesnt seem to have helped much. I dont know if maybe there is something wrong with the thermostat or something more. If anyone can help please do so as I would like to get this fixed so that I have heat again.
thank you,
niceguy4u36
Old 01-22-13, 09:55 AM
What does your engine coolant temperature gauge say?
Old 01-22-13, 09:58 AM
The temperature gauge shows a normal temp...its not running hot or anything like that. It gets to about right in the middle of the gauge.
Old 01-22-13, 10:00 AM
There is either an obstruction preventing the door that sends out the heat from opening [probably under/behind the glove box] or for some reason water isn't flowing thru the heater core. Most likely it's a vent issue.
Old 01-22-13, 10:12 AM
I can't remember if that van has a valve to prevent coolant from cycling through the heater core when the heat isn't enabled or not. If it does, the stopleak might have gummed it up.
Old 01-22-13, 07:16 PM
iceman681's Avatar
these are bad for the blend door motors going bad. but first make sure if both your heater hoses are both hot. if one is and the other is not, your heater core is plugged, if both cold, air and you need to fix your leak. if both hot blend door issues. if it has dual heat. check passenger side for heat to conform.
Old 01-23-13, 08:34 AM
Wonder If your AC is working or not. If valve got stuck. Try banging a bunch of times on middle of dash. Believe it or not....it worked with one car.
Trackbacks are On
Pingbacks are On
Refbacks are On
