1990 Honda Accord Driver Side Turn Signal Light Flash Faster Than Passenger Side
Old 01-23-13, 03:45 PM
1990 Honda Accord LX, 4 DR, AT, 234,270 miles. Driver side turn singal light flash 2-3 times faster than normal passenger side. All lamps are working including brake lamps. Need help to know what cause this problem.
Old 01-23-13, 04:35 PM
ukrbyk's Avatar
Bulb will fail soon. Or it's aftermarket bulb with wrong resistance or whatever.
Old 01-23-13, 04:52 PM
One of rear brake lamps was changed with OEM lamp many years ago and don't have this problem until recently. Since all lamps are still functioning, I will wait until it goes off to fix it. Could it be another problem other than lamp?
Old 01-23-13, 06:45 PM
Not likely.
Could also be caused by a corroded lamp socket.
The problem will be in the side that blinks faster.
Old 01-23-13, 07:03 PM
ukrbyk's Avatar
I was told long ago, that bulb resistance changes, and then bulb goes boink. That's how you know that bulb is bad - blinker blinks much faster.
Old 01-23-13, 07:52 PM
iceman681's Avatar
compare the brightness of the bulbs. the one that is brighter/dimmer will be it.
