2002 Dodge Grand Caravan Transmission Fluid Specs
I just recently rebuilt my transmission for my 2002 Dodge Grand Caravan and am about to buy the fluid. Does anyone know if there is a specific type of transmission fluid to be used in the year make and model of vehicle? I know that dodge and jeep are sometimes weird about that kind of thing. Is regular ATF okay?
At double the price of regular (I think), not sure I would spend the extra $$$ on a 12 year old Caravan even when rebuilding tranny unless rest of vehicle and engine were pristine.
Have seen it happen when I worked for Dodge dealer as partsman, and since proved it to many friends, as well as seen postings on "Allpar.com" that anything other than using Mopar ATF+4 is taking a chance. That is the new recommended fluid for Chysler/Dodge tranny's and is compatible to add to ATF+3 if necessary. Before ATF+4 from Mopar, obviously it was ATF+3. I did find one article on why other brands shouldn't be used but cannot find it again, but have seen and heard numerous times of another brand that a lot of mechanics swear is compatible, as well as the manufacturers, and sellers, that just don't work right with Chrysler tranny's, and cause shifting problems etc, only to dissappear when fluid dumped and replaced with Mopar. Up to you, but I always insist on Mopar tranny fluid only, just because of what I have seen, let alone heard from others. Yet I have seen next one run fine, but I only want to do it once, and won't take the chance.
