2000 Grand Prix Power Steering Problem
Old 04-13-13, 08:47 AM
D
So, here's what happened:
Just started making noisy power steering sounds when we started turning the wheel over the winter. Happens when turning both directions the entire time you drive the car.. Tolerable when turning, but annoying. We've put about 7000 miles on the car in 2 years - just need it as a backup to our other vehicles. I'm not an expert mechanic by any means, but if there's a simple solution, or if you can give me an idea of the cost of the repair, I'm just curious so I can plan our family budget accordingly. Thanks ahead of time for your input!
Old 04-13-13, 02:16 PM
D
So, fortunately, it was as easy as adding more power steering fluid, but I'm still kind curious. It fixed most of the resistance when turning the wheel, but when I turn left there's still a loud noise occasionally, but it works good enough for now. What I'm curious about is since we've ever had it, it's made a small whirring sound, which later turned into this power steering problem (I believe). The whirring sound was faintly present when idling, fairly noticeable when hitting the gas, and then tapers off a little bit when taking your foot off the gas. I'm assuming its related to the power steering problem, seemed like a precursor, but not an experienced mechanic so don't know for sure. It's not a wheel bearing - I've had those before.
Thoughts?
Old 04-13-13, 02:45 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Bad idler pulley? Does this have a single serpentine belt?
You shouldn't normally have to add much PS fluid unless it's been neglected or you have a small leak.
Old 04-13-13, 03:27 PM
D
The fluid could have been neglected - I certainly haven't touched it in the 2 years we've owned the cars. Could be a leak, but the fluid I got says it's both fluid and for preventing leaks, so hopefully it helps if there is a leak too. Don't know anything about the other 2, but will keep apprised of the situation and see how it goes - thanks for your reply!
Old 04-13-13, 04:37 PM
ukrbyk's Avatar
Received 7 Votes on 6 Posts
C/P
Power steering noise
When the fluid is low and you add some, it may still need more after you run it for awhile. The reason is that as the pump pumps the fluid through the lines, this also normally pushes any air out the lines. Keep filling and checking after you start the car and turn the wheel from side to side all the way.
The bigger question is why do you need to add fluid? After you locate and fix that leak, you can address the whine. If it is a Ford, it may be somewhat normal. Like Drazi said, "It may be air trapped in the line." Or the pump may be damaged from running it dry, or there is bilge in the line, starving the pump. Let's assume you have kept up on the maintenance and have flushed the fluid when it was dirty. Let's also assume that the pump is not damaged and you have found and fixed any leaks. Try this: pull the fluid out of the reservior and add one bottle of Lucas brand power steering additive, and top with power steering fluid. I have found this stuff pretty good at resolving many power steering problems. I'm not a big supporter of "Snake Oil", but have had good luck with it.
If it's a Ford, it's because they use plastic parts in their casings, though most other car companies do the same. If that's not the case, then your pump is receiving too much stress from turning. Try lubing up the chassis and changing the fluid completely. It wouldn't hurt to check your lines either. Sometimes blockage can cause too much stress on the pump too.
First thing is why are you adding fluid. If it has a leak, then I would address that problem first. A pump will not bleed air out of the system if it is leaking. If everything seems to be okay and your pump still whines, then replace the pump, preferably with a new one from the dealer. The so-called rebuilt pumps that you can buy from places like Autozone, O'Reilly, etc. are cheaply rebuilt, especially if it's a Ford. They don't bleed out air properly, resulting in improper pump pressures. A good pump will bleed out almost immediately, with the turn of the wheel a few times. If it doesn't, then your pump will more than likely never completely bleed out. Buy a new pump from the dealer--it costs more, but if you're like me and don't like the noise, then it's worth it.
You probably have air trapped in the power steering fluid system. Bleed the air out by revving the engine to about 1500-2000 rpms and turning the steering wheel almost all the way from one side to the other a few times. This should bleed out the air and take care of your problem.
If the noise is similar to that of a dry bearing, then the problem is probably the power steering pump itself. If the noise you hear has a "click, click, click" to it when you make turns in your vehicle, then the problem is more-than-likely your CV joints. If the noise is screeching, check your belt for wear-and-tear and proper tension (see owner's manual), and the pulleys that the belt turns, including the air conditioning compressor motor and its clutch/pulley.
I just wanted to add another two cents about the topic of bleeding or burping the power steering system:
1. Know what type of power steering fluid is needed for your car. Some power steering pumps can use automatic transmission fluid, others have specific power steering fluid for each car, i.e. Honda requires and suggests that you use Honda's brand of power steering fluid (see owner's manual). Make sure you know, or the warranty from the dealership or from the parts store may be voided.
2. Before attaching the power steering belt, fill pump with required amount and type of fluid (see owner's manual), and then turn the pulley wheel by hand a few times. This helps cut down on dry turns before they can happen. If more power steering fluid is needed, fill accordingly.
3. Attach the power steering belt with proper amount of tension (see owner's manual).
4. Turn vehicle on and proceed to turn the steering wheel all the way right and left 3-4 times.
5. Turn the vehicle off, and examine that the belt tension is acceptable, and again check the level of fluid and fill accordingly.
6. Always, always check your owner's manual before performing any maintenance on your vehicle. An educated car owner is a safe car owner!
Another_possibility">Another_possibility">Another possibility
How long has the pump run without fluid? There could be damage inside to the cam and rotor (assuming it's a vane type pump), or to the plates, or it could be cavitating due to the ingress of air -- possibly why the fluid leaked out in the first place.
Powerbrake and Steering :: Homepage
I too experienced very loud whining noise from my 93 Ranger 3.0's power steering pump at idle, and even louder when turning the steering wheel even a little bit in either direction. I changed the fluid but there was no change in noise. I read in a Ranger forum that if you add some STP oil treatment (yes, STP OIL TREATMENT), not the whole can, it would help. I decided to give it a try and sure enough it has reduced the noise greatly. It didn't completely eliminate it but people no longer stare at my vehicle at red lights because of the noisy pump. That was embarrassing! Ford's pump must be partly to blame since the problem is so rampant among all their various models.
Old 04-13-13, 04:39 PM
ukrbyk's Avatar
if the noise is a high pitched squealing noise, the belt is slipping....if the noise is a whine or growling noise, the pump is low on fluid or the pump is bad
Old 04-13-13, 05:57 PM
ukrbyk's Avatar
Vic mentioned to me that in cp I did for the OP, Ford is mentioned several times, while vehicle in question is, originally, GM product.
Vic, I do agree that those are different makes, but I feel, article posted is generic to any domestic power steering system, and should help for Fords or for GMs.
But you friendly guidance is appreciated, as usual.
Old 04-14-13, 06:26 AM
D
Very helpful - a "whining" most accurately describes what I'm hearing and hopefully the fact that the fluid I purchased is also for stopping leaks will in fact seal any leaks that occur. It's been whining since we got it, and the major problems (resistance to turning and louder rumbling) began about 18 months after purchase, which would be consistent with a very slow, small leak. Thanks much for this and I will look to add more fluid and bleed air out of the pump!
Old 04-14-13, 09:46 AM
A
Danstelter,
Spend time carefully reading the link below. This link is about TSB'S. TSB means TECHNICAL SERVICE BULLETIN. A TSB is not a recall. Just think of it as a repair procedure for repairing an issue (or issues) that are unique to a vehicle (or a particular group of vetches). As it turns out there are 91 TSB'S for steering and suspension issues on your car. You need to discuss these TSB'S with your mechanic, because applying one or more (not necessarily) all 91 could resolve your issue.
2000 Pontiac Grand Prix TSBs (Technical Service Bulletins) | PontiacProblems.com
Thank You
Amy
