2002 ford taurus cranks but no start
checked fuel pressure and spark, no fault codes due to the fact that battery was disconnected. what steps to take next
have you tryed putting your foot on the gas while starting? the idle air control valve loves to stick on these.
Dhope63,
How are you checking for fuel delivery, and is fuel reaching the plugs?
How are you checking for spark delivery, and is spark reaching the plugs?
Is cylinder compression adequate?
Have you ruled out an excessive back-pressure issue?
Have you ruled out a timing chain issue?
Thank You
Amy
Thank You
Amy
