headgasket ford taurus 94 3.0
Old 05-10-13, 10:36 AM
needing a lil help with ford taurus head gasket
i have changed my head gasket and once i got everything all back together it wont start doesnt even sound like its tring i tested the spark on the plugs and they are sparking and its getting gas but i did not set tdc when i had the heads off could that be the problem? any help would be great
Old 05-10-13, 11:13 AM
the_tow_guy's Avatar
Received 52 Votes on 42 Posts
Or your valve timing could be off; check alignment marks on crank and cam.
Old 05-10-13, 12:30 PM
thanks
thanks but can i set the timing without haveing to strip the engine again?
Old 05-10-13, 07:38 PM
iceman681's Avatar
Received 3 Votes on 3 Posts
just have to ask who set the timing the first time?
Old 05-11-13, 06:19 AM
Trying to remember what a '94 3.0 has, belt or chain. Either way, have to access the sprockets to check the alignment. Was the head checked/serviced at a machine shop while it was off?
Old 05-11-13, 11:49 AM
A
jujubofak,
You stated your vehicle is a 1994 Taurus 3.0.
By chance did you fail to mention that it’s an “SHO”?
With that being said, do you realize how (the SHO factor) changes the "Playing Field"?
Thank You
Amy
