Can you bypass the abs on a 91 buick with a metering valve
Old 05-13-13, 06:25 PM
G
91 buick park ave front drivers side..seems like something is locking down replaced the caliper, brakes on the front, abs pump and the rotor worked fine for a day now its doing the same thing you can smell it getting hot any advice would be nice ..can you bypass the abs and put a metering valve on it??
Old 05-13-13, 09:20 PM
Received 2,966 Votes on 2,676 Posts
Welcome to the forums.
I can't answer your question about the metering valve but your problem could be a defective flex hose.
Rubber brake lines break down internally and the pieces can cause a blockage.
Old 05-14-13, 07:33 AM
the_tow_guy's Avatar
Received 153 Votes on 118 Posts
Second PJ's comments.
Old 05-14-13, 07:45 AM
G
ty we will try and see if that is it we have about had it with this car
Old 05-15-13, 03:12 AM
A
gray2863,
Answer to your question is no. You'll damage the ABS system, and set multiple ABS error codes. I agree with the brake hose theory, but are you able to scan the ABS module, and post any error codes that could be set?
Thank You
Amy.
Old 05-20-13, 07:09 AM
G
We replaced the hose and it works thank yall so much.....I have drove it to South Carolina which is about 3 1/2 hours from where I am and no problems....Thanks again
