89 toy Camery 2.0 auto , pass side axle squeel and vibration
Old 05-28-13, 06:08 PM
I think it`s the bearing were the axle go`s into the trans case ! Anyone know if that bearings replaceable from the outside ?
Old 05-29-13, 06:07 AM
the_tow_guy's Avatar
Not in that area of the trans, but the axle shaft on that side I'm pretty sure has a mid-shaft bearing; that could be the problem. Also the wheel bearing and cv are possibles, although a squeel would probably be bearing rather than CV. Will have to check diagram on that vintage Camry.
Old 05-29-13, 06:13 AM
You can see the mid-shaft bearing on the shaft here:
1989-1991 Toyota Camry Axle Assembly A1 Cardone, Front, Passenger Side, OE replacement
It is housed in ether in a motor mount portion or in a separate bracket.
