Squealing A/C compressor
Old 06-02-13, 12:20 PM
I have an 98 Ford escort ZX2. The issue with the car is that whenever I have the A/C on the car blows cold air out but, it makes a loud squealing noises when in idol. It tends to sound like a bad bearing or the A/C is going out like something not greased. But could it be low on freon or compressor oil? Please Respond!
Old 06-02-13, 03:48 PM
Received 835 Votes on 782 Posts
Welcome to the forums.
It would not have anything to do with freon charge and I doubt compressor oil either.
Have you tried turning the air conditioning off to see if the noise changes at idle ?
Your problem sound like a front compressor bearing. I'm not sure what is involved in replacing it.
Old 06-02-13, 03:53 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
It could also just be a slightly loose/stretched belt or a worn tensioner pulley. At idle, if the compressor cycles on and off...it sucks a lot of power from the engine for the compressor as well as the alternator, causing slippage.
Old 06-03-13, 07:44 AM
Sound stops immediately when the air conditioning at idol.
Old 06-03-13, 07:47 AM
Well I had the belt replaced twice last because of the belt breaking.
Old 06-05-13, 09:39 PM
Still not fixed!
I've went to a junk yard pulled an original compressor apart found out the whole clutch system isn't based on bearings but half cylinders and I rotated the clutch while the car was off and there was no noise thinking belt tensioner any ideas?
Old 06-06-13, 03:06 AM
A
John,
The red flag here is your claim that the squealing sound stops immediately when the air conditioning is idle. In other words, your A/C compressor is on the verge of failing. The word "Verge" is the operative word here, and explains why your still getting cold air when the A/C is on, and why the noise is gone when the A/C is off. Look at it this way, if it was another component (alternator for example or a belt tensioner), you would have the squealing noise regardless of the A/C being idle or not.
Thank You
Amy
