How to remove '1' cylinder Head bolt head by drilling?
Old 06-13-13, 05:50 PM
H
Hi Guys-
So I am trying to do a Headgasket on my 1994 Accord EX F22B1 because of overheating issues.
Long story short, I am unable to pull the head and do Headgasket because of '1' Damn bolt.
I am drilling on the bolt right now with a Milwaukee drill bit and used engine motor oil as a cutting oil.
I am kind stuck now, not sure how to completely remove the head of the bolt, so I can pull the head?
Please have a look on the pictures and advice, I am kinda stump now. Because if I try to drill by using 9/16', it's not removing anything and seem like bolt head is not budging.
Thanks in advance for all of your help and advice.
Old 06-13-13, 06:09 PM
Received 1 Vote on 1 Post
It's a grade 10.9 bolt. (very hard)
You should be using a left hand colbalt drill or something like this.
Craftsman 6 pc. Power Extractor and Damaged Screw Remover - Tools - Power Tool Accessories - Drill Sharpeners & Attachments
You need cutting oil not used motor oil, all your doing is hardning the metal as your trying drill it.
Old 06-13-13, 06:56 PM
iceman681's Avatar
Received 5 Votes on 4 Posts
need to start with a small bit and step up. it will cut better. and you wont have to go to deep just enough to get the head off.the rest of the bolt should come out easy once the head is off. and watch your shavings. id put a strong magnet real close by to catch them.
Old 06-14-13, 03:14 AM
A
helpme81,
Visit the link below this tool is incredible.
Broken Bolt Extractor Kit | Remove Broken Bolts | BrokenBolt.com
Thank You
Amy
