Trooper AC ReCharge
Old 06-30-13, 08:53 AM
Trooper AC ReCharge
Our 1988 Isuzu Trooper is needing some freon as its showing bubbles passing the sight glass although it's still cooling fairly well. It's been a few years actually since I added any last and it's still an R12 charged system. I have some R12 left that I was going to add in but when I start to take the cap off the low side schrader valve, I can hear a hissing sound like the gas in the system is trying to escape. What can I do?
Old 06-30-13, 08:59 AM
The only thing I can think of is that you will have to take it to a mechanic that does AC work and have him evacuate the system so that the valve insert can be replaced. Then he could re-charge and add what you have left.
You can't move fast enough to replace the insert without losing a lot of the charge.
Old 06-30-13, 09:07 AM
Gunguy45's Avatar
Super Moderator
Sounds like you need a Pro service. Likely that the schrader has been slowly leaking. They have a tendency to do that. I've had one of mine replaced twice.
Put a little soapy water or spray it with an all purpose cleaner...bet you see bubbles.
Have to evac the system, replace the valve(s), then refill to spec.
Trackbacks are On
Pingbacks are On
Refbacks are On
