Chevy Venture Van water in the cabin
Old 07-04-13, 08:21 AM
C
I have water on the drivers and passengers floor. I searched for the evaporators drain tube to blow it out and I can't find it. Where is the drain tube?
Chevy Venture Van 2002 LS
Old 07-04-13, 08:29 AM
D
Received 235 Upvotes on 186 Posts
I found this out there...
"Dreain is located under the hood in engine compartment on firewall area on passenger side of vehicle, look for a rubber looking hose down low on the firewall, normally you can remove hose and clean drain by blowing air in tube or sometimes crrap collects in the rubber tube, tube should pull right off, i have sneeped off end of the rubber tube so it has a bigger hole to drain and not plug up again"
Old 07-04-13, 08:38 AM
D
Also, look over this info here (different site from above), there is some related info here. Not all of it answers your question but 2 or 3 places offers some really good advice..
Chevrolet Venture Heating / Cooling - Car Forums - Edmunds
Old 07-04-13, 10:25 AM
Received 3,740 Upvotes on 3,356 Posts
Welcome to the forums.
Normally if you have a condensate leak the water is only on the passenger side. Is this water related to the air conditioner or do you find it after a rainstorm ?
