motors for a 1998 camaro
Old 07-11-13, 10:03 AM
what all motors will work in a 1998 Camaro without swapping motor mounts and all out
Old 07-11-13, 10:13 AM
Gunguy45's Avatar
Super Moderator
Might depend on what you have now? V6 or V8?
Most junkyards have an interchange book that will tell you what will fit. I imagine almost any GM engine (same cylinder configuration of course) from around the same period would work.
Old 07-11-13, 10:19 AM
where can I find a motor
what all cars carry a v6 3800 motor
Old 07-11-13, 10:23 AM
the car has a v6 3800 in it now
Old 07-11-13, 10:58 AM
It would be helpful if you provided more information such as what company you are interested in. Right off the bat I'm thinking GM, Chrysler and Hyundai.
Old 07-11-13, 01:29 PM
It came out of a 1998 chevy Camaro
Old 07-11-13, 01:33 PM
chandler's Avatar
What you need is an "engine", is that correct? Motors are usually electric, while engines are internal combustion. Do you need the entire engine, short block?? Are you replacing an engine that has gone south? Can the one you have be rebuilt? We'll let you know when you give us too much information so don't be shy.
Old 07-11-13, 01:36 PM
chandler's Avatar
This is a duplicate post to http://www.doityourself.com/forum/pa...ind-motor.html. We need to keep all the threads together, please.
Old 07-11-13, 01:38 PM
Yeah sorry. It is my daughters car she was coming home from school and it lost all power so she thought she ran out of gas. Cause it was low. So I took her some gas. almost 1/4 tank. She made it about a few more miles down the road and it stopped again. We got it cranked again and made it home. A friend of mine came by and said it was locked up.
Old 07-11-13, 01:52 PM
I have merged the two threads and deleted the duplicate posts. Hopefully it will be slightly more understandable now.
Old 07-11-13, 01:56 PM
chandler's Avatar
Was it run low on oil or coolant? If it is locked up, you may need a crate or salvage engine to replace it with. May or may not be worth it unless the car is a keeper otherwise. Engine alone could cost $1500 installed.
Old 07-11-13, 02:07 PM
No it was not ran low in oil or water. The temp. hand never ran high
Old 07-11-13, 02:12 PM
Have you checked the coolant level to make sure? oil too while you are at it. Gauges have been known to fail.
Old 07-11-13, 02:14 PM
Yes I have checked both. And they are still full. We did notice the reserve coolant does have a hole in it
Old 07-11-13, 02:37 PM
Gunguy45's Avatar
Super Moderator
It could have been a number of things...but having a mechanic look at it and do a few basic tests will probably be much cheaper than a new engine if it's something simple. Unless you know someone who can swap the engine (who could also do the basic tests needed) then you'll be going to a mechanic anyway.
The devil is in the details. Could be an oil pump, bad electrical, bad fuel pump, many other things.
Instead of looking for an engine...you should be looking for a reliable mechanic who works cheap (most times those 2 don't go together).
Old 07-11-13, 02:43 PM
I know you can hear the fuel pump running when you switch the ignition. The one that looked at it does some mechanic work on the side. And he told my husband about some that since you cant turn some wheel under the hood it is locked up.
Old 07-11-13, 04:01 PM
chandler's Avatar
If you can hear the fuel pump run constantly with the switch on, then it is a fuel delivery problem. Could be a pick up in the tank. I question the mechanic's knowledge. It is very difficult to turn an engine over with all the plugs in place and valves closed. The fuel pump running is a major issue.
Old 07-11-13, 05:05 PM
Yeah, fuel pump should start, pump up the pressure, and then stop pumping in a span of only a few seconds unless either the engine is using fuel, or there's a leak somewhere in the system.
I've tested engines for being locked up with really, really long breaker bars on the front crank bolt. I think that my breaker bar was almost 3' long.
Trackbacks are On
Pingbacks are On
Refbacks are On
