Frozon Gauges and dead Battery
Old 07-12-13, 10:37 PM
Post Frozon Gauges and dead Battery
I have a 2001 Saturn sl2 When I drive for a short distants My Gauges freeze my RPM, Speedo, Fuel, Temp and the car dies when I try to start it the battery is dead. I have recharged and tested the battery and its OK. When I reconnect the battery the Gauges all go back to normal and it starts fine and run good until the gauges freeze. I Drive it just around the block and it will do the same thing again with the same result.
I would like some feed back Please Frozen and Dead in Ontario
sng1952
Old 07-13-13, 02:19 AM
chandler's Avatar
Welcome to the forums! Have you had the codes read on the car, yet. That would be the first thing to do. Most auto parts stores will perform this free of charge. With that information, you will know more into which direction you should move. Let us know the codes.
Old 07-13-13, 03:33 AM
sng1952,
Sounds like it could an alternator issue. Have an electrical system "Load Test" done. Many shops and auto part stores will do the test for free.
Thank You
Amy
Old 07-13-13, 04:16 PM
I have had the Alternator Load test and it is OK
Old 07-13-13, 04:20 PM
I have checked the codes and the only code that comes up is that the battery voltage is low
Old 07-13-13, 04:54 PM
chandler's Avatar
I would next check the connections at the battery, and possibly change the cables, or at least, the cable ends to ensure proper connection to the battery. Your alternator may be operating properly, but if the connections aren't good, it isn't charging the battery, and it will die.
Old 07-14-13, 08:05 AM
has the battery been load tested?
Old 07-21-13, 04:05 PM
Post Frozen Gauges and dead Battery
As of today I Have Replayed the Battery and The Alternator and the same thing happens.
Old 07-21-13, 04:08 PM
Ok......is the battery dead now ?
Does anything still work in the car.....like dome lights or headlights ?
Old 08-04-13, 05:12 PM
No.. The Battery has been replaced and the Alternator has been replaced as well
after testing the voltage at the Battery term not running and running it is not charging at all the voltage is 12.6 at both times
Old 08-04-13, 07:50 PM
Ok....you measure 12.6v at the battery when it's off or the engine is running. That means that the alternator is not charging and with time the battery voltage will drop until battery goes dead again.
It sounds like you have intermittent wire connections. I would check inside the fuse box under the hood. You will need a meter or test light to check for 12 volts thru the circuits.
If you don't know car wiring or troubleshooting methods then it may be time to enlist the aid of a mechanic.
Old 08-21-13, 07:28 AM
Are you still working on the car or has it been resolved, sounds interesting.
