2004 ford expedition
Old 09-04-13, 07:52 AM
help
i have a 2004 expedition and the front washer pump does not work with the switch. the pump works by itself and i have changed the signal arm where the witch is. I have also swapped relays and still not pump. does anyone have an idea or an electrical diagram as i am sure i have a wiring problem
thanks
Old 09-07-13, 06:04 AM
the_tow_guy's Avatar
Check the repair help section at autozone.com for a diagram. Not the best, but might give you a starting point. Other than that you'll just have to backtrack the circuit with a meter.
