problems with Hyundai Accent
Old 09-22-13, 04:59 PM
D
I have a 2001 Hyundai Accent. My tail lights are out but the bulbs are fine. The dashboard light is out, but all the indicator lights are fine. The rear defroster does not work. Would any of these problems be a bad fuse or something in the relay box. How can I found out what is going on Thank you
Old 09-22-13, 07:09 PM
Received 1,037 Votes on 961 Posts
Welcome to the forums.
I'm not sure about the rear defroster but the tailights and dashlights are on the same fuse.
Check for a blown taillight fuse in the fusebox inside the car.
Old 01-13-14, 01:22 PM
Received 10 Votes on 7 Posts
And what do they think the problem is ?? ...
Old 01-17-14, 01:44 PM
W
Check all the fuses . Remember , if you have a blown fuse , something may be shorted out , causing the fuse to blow .
If a new fuse blows , also , buy a book with the wiring diagram , for your car .
If a bad wire is un findable , I personally would get a roll of wire and run a new wire anc cut / isolate the wire that is shorted .
There are ways to assist / make easier , traceing these things , but I am afraid I am not a good enough word smith to adiquatly describe them . Especially to someone not familiar with electricity . And cars .
Best of luck
Wyr
God bless
