door switch
Old 09-30-13, 08:44 PM
sgull's Avatar
Received 1 Vote on 1 Post
door switch
On my four-door 92 Honda Accord the dome light stopped coming on when the left rear door was opened. Suspecting a bad switch on the door jamb, I removed the switch to examine it and clean the contacts to see if that might help. It's just one wire going to the switch with a female end connection to which the male spade connector of the switch is pushed into. So I disconnected the switch from the wire to examine and clean it, and when I installed it back into the door the dome light then came on (as it should while the door is open). However, when I shut the door, the light remained on. I have the dome light switch itself set to the position that it should only turn on when any of the doors are opened. So I pushed the switch several times, thinking maybe if it were sticking to complete the circuit I might be able to un-stick it and make the dome light go out, but the dome light remained lit. So I removed the door switch again (disconnected it from the wire), thinking for sure that should prevent the dome light from staying on until such time as I could acquire/install a new switch. But, now, even with the switch completely removed, the dome light stays on even with all doors shut. Until I can find/fix the fault, I just switched the dome light to the "off" position where it will not come on at all (unless I move it to "on").
So I guess/suppose the wire to the door switch is grounding out on the chassis somewhere, and I'll have to find out where. But what is baffling me is that before I messed with the switch, I wasn't having this problem with the dome light staying on. In fact quite the opposite, where the dome light would not come on (when that door was open).
Any comments/suggestions to help me troubleshoot will be appreciated. Thanks
Old 10-01-13, 07:27 PM
sgull's Avatar
Update: I seem to have discovered the problem. The second to the last door switch has rather a rather worn contact spring doo-hicky inside that prevents it from opening the circuit each and every time the door is shut. After fiddling with it a little I got it working okay most of the time, and plan on getting a new switch, or two maybe.
Old 10-01-13, 10:34 PM
Received 933 Votes on 870 Posts
Strange problem. If you remove the switch the light should not work. You said you had the switch out and the light stayed on.
Old 10-02-13, 08:51 AM
sgull's Avatar
I neglected to mention that at first the dome light wasn't coming on when any of the four doors were opened. I removed, cleaned, and then reinstalled each switch separately. By cleaned I mean scraped away any obvious dirt/corrosion and shot them with a little WD40 and worked them back and forth. I took out a switch, cleaned then reinstalled it, operated the switch manually with the door still open to see if the light would turn on and back off, then when I could see it was working would move on to the next switch. After I reinstalled the fourth door switch I discovered the dome light was remaining on even if I pushed that switch, or as I described even when I removed that switch. My first assumption was perhaps the wire to that switch was touching metal somewhere, grounding the circuit.
I decided to remove each switch to see if the light would go out. When I removed the second to last switch (at one of the back doors), the light did indeed go out. I hooked up that switch again and worked it back and forth, and noticed it would not always shut the light off with every push. I took it apart again and could see a little spring contact mechanism wasn't fully moving as it should. I worked it back and forth quite a bit and seemed to get it loosened up and working better, shutting off the light pretty much each and every time I pushed it. After I reinstalled that switch and the last switch, the light will go on/off when any of the doors are open/shut.
I probably shouldn't have used the WD40 to clean the switches. I read that worked for some people. But then I read some people say that'll just eventually gum up the switches. Probably should've used electric contact cleaner stuff. Too late now.
