1998 Maxima Code P0465 - Check Engine light is on
OBDII Code P0465 - Purge Flow Sensor Circuit Malfunction ...
This code is coming up on my Nissan Maxima and I have no idea where to go with it as far as a repair...
we did clean out the EGR valve hose previously...
Any ideas! help!
Any ideas! help!
Purge flow system is the fuel tank evap emission control; completely different system from the EGR.
Here's some general info:
EVAP Evaporative Emission Control System
before you spend any money I would check the vacuum hoses going to the purge motor (probably near the left rear wheel) Remove the hoses and look to make sure they aren't blocked. My altima hose was blocked with a moth nest.
good luck
good luck
