Noob Question need help!
Old 10-03-13, 07:32 PM
I've problem to identifies the car components under my GM car. I hoped someone could help me identify whats components is it for A,B,C.
I need to confirmed is that picture 3(label as D) showing is my mounted timing belt location, right.
Thanks.
[ATTACH=CONFIG]18708[/ATTACH]
[ATTACH=CONFIG]18709[/ATTACH]
Old 10-03-13, 07:39 PM
iceman681's Avatar
a wiper motor, b portioning valve, c brake master, d timing cover.
Old 10-03-13, 07:42 PM
the_tow_guy's Avatar
You didn't mention what make/model.
Not sure what a is; hard to tell from angle of the pic.
B is brake fluid reservoir/master cylinder and C appears to be a brake manifold of some kind, just a big junction for the brake fluid to be directed from the master cylinder out the brake lines to the wheel brakes.
D is timing belt cover.
Old 10-03-13, 07:45 PM
I saw the wiper motor, but was looking at the silver rod/bracket above it; thought that was what he was indicating, but you're probably right. Ditto on the proportioning valve; had a brain fart there. I was still typing when you posted, ice.
koklimabc, is this just for general knowledge or do you have some difficulty.
Old 10-03-13, 07:52 PM
wooh, good respond, Thanks to all! Yeah i'm difficulty to undertand for these things because this is my new bought of car.
