Toyota Sienna 06 visor vanity mirror light burn out.
Old 10-06-13, 02:37 PM
cmpstrctrs's Avatar
A visor light burned out and as I pulled it out with a small screw driver I saw a spark. I initially thought I touched both +/- terminals simultaneously and blew a fuse. But all fuses are Ok. Also, none of the interior lights work any more.
Any ideas?
Old 10-06-13, 02:49 PM
You blew a fuse. It's inside the fuse box that is under the hood. It should be listed in the owners manual.
Old 10-06-13, 10:08 PM
cmpstrctrs's Avatar
Thank you. I will double check.
Old 10-08-13, 09:12 PM
cmpstrctrs's Avatar
Thank you. It was a fuse in a box under the hood by the air filter. I initially only looked in the fuse box Blythe steering wheel column.
Old 10-08-13, 11:00 PM
You're welcome. You'll find many "always live" fuses now under the hood instead of inside the vehicle.
