2004 Mercury Mountaineer - exclamation point light on dashboard ???
anyone know what it means?
From the owners manual for your vehicle (page 11) :
Brake system warning light: To confirm the brake system warning light is functional, it will
momentarily illuminate when the ignition is turned to the ON position when the engine is not running, or in a position between ON and START, or by applying the parking brake when the ignition is turned to the ON position.
If the brake system warning light does not illuminate at this time, seek service immediately from your dealership. Illumination after releasing the parking brake indicates low brake fluid level and the brake system should be inspected immediately by your servicing dealership.
Driving a vehicle with the brake system warning light on is dangerous. A significant decrease in braking performance may occur. It will take you longer to stop the vehicle. Have the vehicle checked by your dealer immediately.
Joe is correct. That exclamation point inside the tire is for inflation. The other exclamation point I was referring to says brake over it.
