97 ranger brake locking up?
Old 10-09-13, 06:36 PM
I have a 97 ranger 4wd that I bought wrecked 2 years ago. The right front brake locks up. it was a daily driver they guy bought from. It sat for about six months b4 I fixed and got on road. The left rear wheel cylinder was leaking fluid from the line conecting to it. I tightend the line (stopped leak) flushed and bled entire system. Replaced the right front caliper. Still locking up. No abs light. The left rear brake shoes were saturated In fluid. I cleaned them with brake clean. Could that cause the right front to lockup?
Old 10-09-13, 06:59 PM
lawrosa's Avatar
Super Moderator
Possibly the guide pins are bent or the mounting bracket itself causing the pins not to slide back...You greases the pins right?
No I dont think the back would have anything to do with the front locking up...
Old 10-10-13, 03:37 AM
You might try replacing the brake hose also, sometimes they collapse on the inside causing the brakes to not fully release.
Old 10-10-13, 05:31 AM
Check the left frt. caliper it may be stuck causing the right one to do all the work.
Trackbacks are On
Pingbacks are On
Refbacks are On
